New issue 929
Old Mar 25, 2009 | 08:42 PM
bcr929stunter's Avatar
Default New issue 929
OK new issue Still cant get power to fuel pump so I bypassed it. Does the fuel pump need constant prime? I run it to a switch prime it it starts and run then dies. Then I tried it when it starts to die I prime it again and it runs strong. So i gave it constant power to the fuel pump and it runs strong. My question is is this right and does it need constant priming?
Old Mar 26, 2009 | 12:14 AM
tomp's Avatar
Once the bike is running the fuel pump runs consistently.
"Since a fuel pump it draws a lot of current (more than we'd like to see going through the ECU itself), it is powered with +12-l4v from the battery via a relay, which is switched by the ECU. Many systems will cycle the fuel pump for several seconds at key-on, then power down the pump until after the bike's engine is turned over. This ensures proper system pressure during starting." (Motorcycle Fuel Injection Handbook)
Old Mar 26, 2009 | 07:57 AM
So do you think its my ECU ? I dont think its allowing the realy to open.. I will probally make this problem worse without having a relay..
Old Mar 26, 2009 | 09:03 AM
justasquid's Avatar
Are you getting power to the relay? Are you getting power to the source on the relay when you first turn on your key?
I would take a volt meter and check the power to the two power supply points for the relay. Remove the relay and test those spots. Im not sure which one are which, but you should have one constant power, and one that will cycle when the key is first turned on. If you have both of these present, I would suspect your relay is bad. turn you key on and check for the constant, then, start checking the others. Put your probe on one, cycle the iginition and see if you get power. Then do this to all of the other points. The main supply should be around 12 volts. But the other is only a signal and is minimal. you will need a volt meter that reads small voltages. It will probably be around .3 volts or so.
I would doubt your ecu is bad. It possible, but the most likley problem is the relay, the fuse, or your BAS. Im not sure if the BAS on that bike shuts power off to just the fuel pump, or the fuel pump and the spark. A lot of bikes its only the fuel pump, but on some its both.
Sprock
Jan 16, 2014 09:15 PM
Nos325
Jun 28, 2013 07:32 AM
markybwoi
Apr 11, 2011 11:35 AM
Snoman
Mar 11, 2010 11:47 AM
StangLou
Sep 1, 2007 08:49 AM
