possible cct issue?
Old Mar 9, 2010 | 06:22 PM
Snoman's Avatar
Default possible cct issue?
hey guys i was just riding the bike around and noticed that i have a little rattle around 5k rpms. now i know about the cct issue with the f4i but im not sure if im having that issue as the noise only comes on in first or second gear and only when im at half throttle in any other gear or at full throttle in second (never been full in first for obvious reasons) there is no noise. is this the cct or just a rattle? and if it is cct should i just avoid that throttle in those gears, or should i look into the manual one?
Old Mar 9, 2010 | 07:17 PM
jonld's Avatar
probably is cct noise but I wouldnt worry about it. I have yet to have a auto tensioner fail and I have about 80k miles between the f4 and f4i. The manual gave me more problems than the auto(had one on the f4i for a short period). now my crf450 is another story, manual all the way there.
Old Mar 9, 2010 | 07:45 PM
929pimp's Avatar
Yep its your CCT.....mine does the same thing I wouldn't worry about it. If the noise bugs you get an APE Manual one.
Old Mar 9, 2010 | 08:12 PM
jondevos's Avatar
Personally I went with a OEM auto one. I would always be paranoid that I set it wrong if I went with a manual one. When I went to the dealer to buy one they said that they have made changes to them to fix the problem. The new one had 2 blue dots on it if i remember correctly. Cost was only $42 canadian and took me less than 2 hours to replace. My vote is stick with auto but many ppl here swear by the manual ones.
Old Mar 9, 2010 | 10:05 PM
Snoman's Avatar
so i should replace it with a new auto one? or just leave it alone?
Old Mar 10, 2010 | 04:05 AM
RunwayOneSix's Avatar
I have the APE manual one and here's a rule of thumb to go by. If you plan on doing the installation yourself, go with the "newest version" of the auto one. Look up the part no. and make sure that's the one you get.
If you don't exactly plan on doing the installation yourself, find a shop that has mechanics experienced in installing the manual CCT and get the manual one. I have the manual one and you can't understand how much more I luv my bike...my last CCT was a pain in the butt...not only was it making the noise, but oil was also leaking through the failed CCT. BTW, my last one was an auto. I now run APE manual
Old Mar 10, 2010 | 01:15 PM
gissmo50's Avatar
i have the same problem and wondering how difficult it is to change the cct to the "newer" version of the auto?
Old Mar 10, 2010 | 03:56 PM
Snoman's Avatar
yea im gonna do it myself with a new auto one any idea what the newest part number is or where to pick one up?
Old Mar 10, 2010 | 09:15 PM
vangill's Avatar
July 2010 ROTM
LIFTER, TENSIONER
14520-MBW-J24 (replaces 14520-MBW-J23)
GSKT, TENSIONER HOLE
14523-MAL-A00
tensioner and gasket-those should be good at your honda dealer.
Old Mar 11, 2010 | 05:51 AM
+1 on vangill...he's the man. That's the part no. for the newest one!
