new clutch
hello all....i've been having clutch difficulties (i believe)....for example in 4th, 5th, & 6th gear...i will be around 7,000RPM's and if i try to accelerate hard (crack the throttle) the RPM's just "fly" up...i can get all the way up to 10-12,000RPM's but with a lot of highway and a lot of patience...
i'm thinking its my clutch plates...does this sound correct.
i've been looking for clutch kits...any suggestions between the difference of a Barnett complete kit (steel plates, friction plates & springs) in Carbon Fiber for $106.95 or do i go with EBC SRC Series (kevlar paper lined) for $74.50
any and all suggestions most appreciated...
2000 cbr600 f4
2000 cbr600 f4
thank you all for your responses...fish, it does happen in the lower gears just not as pronounced.
just wanted to make sure before i spend the money for the clutch and make the bike sit for the weekend
thanks again
thanks again
That deffinitely sounds like a clutch problem. I have always liked barnett clutches personally. They're a bit stiffer than stock but if that doesn't bother you then I'd go for it. I don't know to much about the EBC setup though so I can't really compare the two.
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
