new clutch
Old May 3, 2006 | 07:28 PM
cbrcamel's Avatar
Default new clutch
hello all....i've been having clutch difficulties (i believe)....for example in 4th, 5th, & 6th gear...i will be around 7,000RPM's and if i try to accelerate hard (crack the throttle) the RPM's just "fly" up...i can get all the way up to 10-12,000RPM's but with a lot of highway and a lot of patience...
i'm thinking its my clutch plates...does this sound correct.
i've been looking for clutch kits...any suggestions between the difference of a Barnett complete kit (steel plates, friction plates & springs) in Carbon Fiber for $106.95 or do i go with EBC SRC Series (kevlar paper lined) for $74.50
any and all suggestions most appreciated...
2000 cbr600 f4
Old May 3, 2006 | 08:11 PM
dwhite645's Avatar
Default RE: new clutch
Do you have freeplay in the clutch handle? If you do, it certainly seems like the clutch is slipping and time for a new one.
Old May 4, 2006 | 07:24 AM
shraz's Avatar
i think i got the same problem
but i believe it's because im not closing the throttle enough
Old May 4, 2006 | 09:53 AM
kiggy74's Avatar
Sounds like a clutch to me.
Old May 4, 2006 | 10:44 AM
fishfryer527's Avatar
I gotta say clutch also, but it is strange it doesn't happen in the lower gears too.
Old May 4, 2006 | 10:52 AM
cbrcamel's Avatar
thank you all for your responses...fish, it does happen in the lower gears just not as pronounced.
just wanted to make sure before i spend the money for the clutch and make the bike sit for the weekend
thanks again
Old May 4, 2006 | 10:11 PM
kustom98f3's Avatar
That deffinitely sounds like a clutch problem. I have always liked barnett clutches personally. They're a bit stiffer than stock but if that doesn't bother you then I'd go for it. I don't know to much about the EBC setup though so I can't really compare the two.
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
