need some Help guys....
Old Oct 9, 2006 | 09:26 PM
mike06CBRrr's Avatar
Default need some Help guys....
just got done installing my HID kit and all i did was extend the wires for the kit, got everything back together and tryed to start the bike up and nothing....took everything back off to see if i forgot to plug something in and didnt all the fuses are good too...just cranks but no fire...could it be the battery??? help me out guys
Old Oct 10, 2006 | 11:54 AM
joesrods's Avatar
Default RE: need some Help guys....
Well it sounds like it is definetly not the battery, or the starter. If you hear the motor cranking than the battery/starter are fine. Sounds like you have an ignition problem, make sure all of the electric connections are plugged in correctly and in their correct place.
Old Oct 10, 2006 | 11:56 AM
TennesseeCBRF2's Avatar
Make sure the engine cut-off switch is in the "run" position. Very basic I know, but maybe you forgot.
Old Oct 10, 2006 | 10:10 PM
got it guys my battery was just low on juice
Old Oct 10, 2006 | 10:14 PM
N8 Dawg's Avatar
ORIGINAL: TennesseeCBRF2
my bike wont even turn over if the switch is off??
I was going top suggest charging the battery, or did you buy a new one?
Old Oct 11, 2006 | 01:30 PM
With the switch in the "off" position the bike will try to start, but it won't. I think the starter spins but the coils won't fire maybe?
speeddemonx60
Feb 7, 2010 11:02 AM
3v1lj03
The Hurricane Saloon
May 1, 2009 09:59 AM
gotcbr
Apr 29, 2009 04:23 PM
Apocal
Jul 23, 2007 08:11 AM
acidfire52
Jul 17, 2007 07:27 PM
