need some Help guys....
just got done installing my HID kit and all i did was extend the wires for the kit, got everything back together and tryed to start the bike up and nothing....took everything back off to see if i forgot to plug something in and didnt all the fuses are good too...just cranks but no fire...could it be the battery??? help me out guys
RE: need some Help guys....
Well it sounds like it is definetly not the battery, or the starter. If you hear the motor cranking than the battery/starter are fine. Sounds like you have an ignition problem, make sure all of the electric connections are plugged in correctly and in their correct place.
Make sure the engine cut-off switch is in the "run" position. Very basic I know, but maybe you forgot.
got it guys my battery was just low on juice
ORIGINAL: TennesseeCBRF2 Make sure the engine cut-off switch is in the "run" position. Very basic I know, but maybe you forgot. I was going top suggest charging the battery, or did you buy a new one? |
With the switch in the "off" position the bike will try to start, but it won't. I think the starter spins but the coils won't fire maybe?
