Need help with parasitic draw 954rr
Old Oct 3, 2019 | 05:48 PM
Vapourinthesea's Avatar
Default Need help with parasitic draw 954rr
Hey guys, I'm a little stumped and need some help. The story goes like this....
I went to ride last week and noticed my battery was dead, barely got any lights to even flicker. Before getting a new battery I know to check for a parasitic draw first. Unfortunately there is one. It's not too bad, only 1.3 amps, but enough to kill a battery. So I start pulling fuses and see that the fuse for "clock/fan" is the circuit it's on. So I pull the fan relay and the draw is there...pull the wires to the fan motor..still there. Pull the speedometer harness and bam, the draw goes down to .13mah vs the 1.3A that it was at. So figuring that there is something wrong with the instrument cluster, I order another one (used obviously) and just got it. Hook it up aaand..... still there. Unplug it and it goes away. I'm not seeing any wires that are standing out as shorting or anything.....now what?
Old May 26, 2023 | 06:11 PM
jimmysone's Avatar
Default Same problem
Hey by any chance did you figure out what the draw is I’m having the same exact issue I know this was posted a while ago but any help would be appreciated
Old May 26, 2023 | 07:01 PM
Hey sorry to hear your having the same issue. Honestly I went through everything and never found the issue, even replacing the dash and other components. Checked everything, nothing. Even cut every wire on the main loom 1 by 1 and still never found it. So when I re spliced everything back together I just went to the auto store and bought a switch. I wired everything to that switch, so when I was riding I would turn the switch on, and when I was done riding I'd turn everything off with that switch. It worked, I hate that I couldn't fix the real issue, but it did allow me to not be stranded all the time. Hopefully that helps in some way.
Old May 26, 2023 | 07:36 PM
jimmysone's Avatar
Thanks for the reply dude. I have it narrowed down to one wire a red and green wire but even that is proving to be difficult to pinpoint what the actual problem is I can’t find a short or anything that would cause the power drain. If I ever figure it out I will let you know. Thank for the help.
Old May 26, 2023 | 07:46 PM
Absolutely, i remember the pain that all was so if i can help, i want to. If you have it down to 1 wire, thats really good. It CAN be the devices that wire goes to. But if you need to, a switch would work. Eventually i just got tired of working on it more then riding, so i sold it and bought a brand new hayabusa. I still have a dash for it though that I don't need. Hope you figure it out!
Old May 27, 2023 | 11:45 AM
dannoxyz's Avatar
red/grn wire only has 3-destinations:
- fan relay
- clocks
- unused connector at rear-left winker
If drain only occurs with clocks plugged in and stops with it unplugged, then wiring is ok. Something inside clocks is shorted and draining. Is your's like OP's where it only drains with clocks plugged in?
Rather than switch, you can wire in relay that's activated by... headlight power. Then red/grn wire's disconnected from clocks when bike is OFF. And is only reconnected when bike's ON.
Old May 27, 2023 | 12:57 PM
jimmysone's Avatar
Default Thank you
I will definitely check those 3 spots for any issues and maybe use the relay if I can’t find anything else thank you for the info
Rapidgrrr
Jul 21, 2019 05:56 AM
canhead64
Sep 21, 2010 01:48 PM
Drewsky
Sep 30, 2009 12:34 PM
A4wheelin
May 30, 2009 03:37 AM
Makez
Dec 10, 2007 11:43 AM
