Need help bad
Old Mar 3, 2019 | 01:28 PM
CaBaRet's Avatar
Does it look like the outside could have been chaffing on body work , can they be separated
Old Mar 3, 2019 | 02:00 PM
Cody Orr's Avatar
outside of the wiring is fine no rub marks just hard as a rock, I forgot to mention this bike sat for a very long time
Old Mar 3, 2019 | 02:02 PM
Cody Orr's Avatar
i think the problem is the blue wire that plugs into the fuel pump itself, if I run a wire from the brown wire to the the blue wire the fuel pump kicks on if I take the wire off the fuel pump does nothing
Old Mar 3, 2019 | 02:18 PM
CaBaRet's Avatar
check this out
File Type: pdf
Old Mar 3, 2019 | 02:45 PM
Cody Orr's Avatar
check this out
thats the one I'm talking about
Old Mar 3, 2019 | 03:05 PM
CaBaRet's Avatar
Are you sure the Fuel cut relay is working , did you swap with the headlight relay
Old Mar 3, 2019 | 03:08 PM
Cody Orr's Avatar
Default Yes
Yes I swapped them out a few times and still nothing
Old Mar 3, 2019 | 03:38 PM
CaBaRet's Avatar
The blue wire is the internal of the pump, could be a faulty pump, did you separate the 3 wires
Old Mar 3, 2019 | 03:41 PM
Cody Orr's Avatar
yes I did, could be, I bought the pump new, just odd how it will power on by running a wire to it from the relay but won't when I take the wire off
Old Mar 3, 2019 | 04:01 PM
CaBaRet's Avatar
It's the only thing left , what was wrong with the previous pump
