Miss fire
Old Jul 6, 2020 | 05:59 AM
Neil1962's Avatar
Default Miss fire
Hi, I have a 1991 cbr600f f2, it seems to have a weak spark, and will always fire on cylinder 3, sometimes not on 1 and 2, sometimes not on 1 an 4. I have replaced the battery, coils, ht leads. Could the pickup coil or cdi cause this sort of intermittent fault. It has fuel and compression, Thanks
Old Jul 25, 2020 | 12:07 AM
rinferno's Avatar
Thumbs up
check your battery for charging, low voltage can cause a weak spark. Test both voltage regulator and stator .Coils dont usually fail. I had a similiar problem, I had a couple of bad wire connections from voltage regulator and and stator connectors. eliminate each one of those items, that should fix your problem. it could be one of those causing a weak spark. Get a manual if you dont have one.
Old Jul 25, 2020 | 10:45 AM
Neil1962's Avatar
Rinferno, thank you for your advice, I will check the things your suggest and report pack
Old Jul 25, 2020 | 10:24 PM
rinferno's Avatar
No problem, let me know what you find.
CBR600FA
Sep 6, 2019 04:22 AM
CBR600FA
Sep 1, 2018 06:17 PM
Chad Brenno
Jun 23, 2014 07:25 PM
michael myers
Jul 19, 2012 07:34 PM
buccilator51
F2 Tech
May 7, 2012 01:15 PM
