Kink in throttle cable
Old Sep 12, 2009 | 11:16 PM
Kuroshio's Avatar
Default Kink in throttle cable
When cleaning the carbs, it's probable that I kinked a throttle cable. Now there's like a stop at half throttle. A little pressure pushes past it.
Any way to straighten out a kink or do I need to replace the cable?
Old Sep 12, 2009 | 11:29 PM
justasquid's Avatar
Can you see the kink in the cable?
If you can see it, try to bend it back and it should be fine. As long as it doesnt start to unravel, if it does, you will have to replace the cable. Also, you might want to check to make sure the cable is not fraid. A lot of times, the condition you described is from the cable fraiying and single cables will fray out and catch the inside of the case. Another thing that can happen is the inner part of the case can becomes rusty and then looses its smooth case and the cable starts to drag.
You may just want to check that you don't have the throttle too tight on the handlebars. Loose up the collar and see if that helps. Sometimes the case gets too tight and drags on the throttle handle.
Also a good cable lube should be used at least once a year to keep rust from forming inside the cable and letting the cable slide freely. It may just as simple as needed to be lubed.
cbr6rider
Apr 20, 2011 08:57 AM
newtjrjrjr
Aug 19, 2008 12:56 PM
283racin
Apr 30, 2008 11:16 PM
angryscientist
Sep 29, 2006 07:51 PM
