just bought 2002 cbr but need help - shifting into 2nd is rough...
Old Feb 23, 2009 | 08:35 PM
jharbinson's Avatar
Default just bought 2002 cbr but need help - shifting into 2nd is rough...
I am a total newbie and bought a 2002 cbr 600f4i 2 days ago. Today was my first day with decent weather and really got some riding in. Pleae help me here becuase I feel like my transmission is going to fall out when I shift into 2nd gear. I'll explain exactly whats happening and let me know if this is normal. When I am in first gear and I shift into 2nd gear but stay under 6000 rpm everything is smooth. When I go over 7000 rpm and higher and shift into 2nd my shifter feels like it is slamming back down really hard into my toes and its not a smooth transition. My shifter feels like its fighting back. This only happens when going from first to second though.... Please let me know if I'm about to have a serious problem with my bike. Its only got 5900 miles on it so I thought this would be something I wouldn't be repairing anytime soon.
Old Feb 23, 2009 | 09:07 PM
justasquid's Avatar
Are you shifting firmly? First to Second gear ****s require a much firmer shift than the other gears as you shifting over neutral. If your wearing plain old sneakers, it will be hard to get a good shift in. If you have a set of low profile boots, try those out and see if its better. If your only giving it a slight bump into second like you do with the other gears, it will do what your saying is happening. give it a quick firm shift.
If you are giving it a firm shift and it is still slamming down onto your foot. You may have a bent shift fork. You can get a bent shift fork at any point, it doesnt really matter on mileage. Improper shifting is the main culprit of bending the shift fork.
Old Feb 23, 2009 | 09:22 PM
jharbinson's Avatar
I was pressing it pretty good and wearing boots so the bend shift rod may be the problem. Is that an expensive fix?
Old Feb 23, 2009 | 09:59 PM
skoobydoobie's Avatar
not if you do it yourself. You can find the parts you need here in the classifieds or eBay. Do a search, I'm sure there write up somewhere. Good Luck, Ride safe.
Old Feb 25, 2009 | 12:08 AM
jharbinson's Avatar
Thanks for the help... I made a concious effort to shift harder and that worked much better. Phew... I thought I had a problem with my bike!
Old Feb 25, 2009 | 01:31 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Another thing that might help you is dropping your rpms just a little more in between shifts. I was having a similar issue shifting and noticed that bliping the throttle utilizing more wrist movement helped my shifts considerably. Sometimes it's so smooth that I don't even feel it pass through neutral (from 1st to 2nd).
joefos
Dec 12, 2013 08:19 AM
Tort93f2
Apr 13, 2012 12:18 PM
DevilInDisguise
Jun 11, 2011 02:58 PM
cbrvegas1k
Jan 13, 2011 02:52 AM
cleansho93
Aug 19, 2007 03:49 PM
