Installing a scorpio alarm on a CBR600 F2
I'm thinking about getting the scorpio SRI500SE. On the scorpio website there is a pdf document thatstates which bikes the factory connector kit will fit on. Most of the bikes are new bikes. Does anyone know if the connector kit will fit on my CBR 600 F2 from 1993. I've tried e-mailing the manufactor but I'm not getting any replies.
Don't bother with the connector kit, it only saves you from splicing into 3 wires.
The PDF and the actual manual (the same thing) tell you the honda rear turn signal/taillight wire colors and they're all right under the rear seat. You also need to connect power+ground -> EASY.
Your alarm comes with all the splicing connectors you need anyway.
The taillight wire is only used to alert you if someone used a screwdriver to start the bike- so I didn't even connect that = pointless.
