Ignition problem
Ignition problem
Hi. Problem with my CBR 600FY. I have electrical power (lights etc) but absolutely nothing happening when I press starter switch. I've checked fuse and the kill switch is not engaged.
I have just put exhaust downpipes back on so entirely possible IVe messed something up (I'm a reluctant and inexperienced DIY mechanic forced into it by poverty...)
It did start once. Then cut out again. No nothing again.
Any suggestions? Thanks.
This could be similar to a problem I had yesterday, but wanted to see what others thought. I turn off the kill switch AND ignition every time. I turned the ignition on, then the kill switch on, hit the start button and everything went dead. No lights, no nothing. Checked all fuses, removed and put battery back, nothing. Friend helped get the bike back home, and he mentioned that sometimes the kill switch causes problems. So, at home, I started playing with the ignition, kill switch, start button, clutch & side stand. At some point, the lights came on. I hit the start button, and voila, bike started right up.
Now, since then, I have tried different combinations to try to get the thing to stop working, but it works every single time. I am not sure where to start, must be a loose connection in the kill switch assembly or maybe the ignition. I want to fix it so I don't get stranded somewhere. Suggestions?
