How to wire the rectifier/regulator?
Old Oct 17, 2011 | 04:10 AM
alexzmc's Avatar
Registered Users
Default How to wire the rectifier/regulator?
HI,
i need help on how to connect the regulator back on my motorcycle (honda cbr 600 f2/94) I know that the 3 yellow dosent matter the order bu i have problems with the red and green wires because this regulator that i have now dosent have colours.My quescion is as i mounted the regulator on his original spot and pozition red is on the low side or the upper.Thank you
here are some pics:
ImageShack® - Online Photo and Video Hosting
Old Oct 18, 2011 | 05:29 PM
bkubes's Avatar
Didn't look, but I'm pretty sure ground is on the bottom. The grounding screw is right below the regulator on the mounting plate.
Edit: I was wrong. When its mounted the ground wire is above the red.
Old Oct 18, 2011 | 06:47 PM
MadHattr059's Avatar
On the original stock r/r for the f3 the wires are...
top row (next to the clip) 3 yellow in a row
bottom row (left to right) left red (+), cntr empty, right green (-)
the orientation is looking in the socket end of the r/r, with the epoxy up, the metal base plate down.
I don't think they made any harness change to the r/r connector between the years, but I am NOT positive of that. it looked from the pic like the r/r is off an '88 600F2.
Is that correct?
Hope this helps, Ern
radman3120
Jul 7, 2017 09:38 AM
rsaari13
Oct 7, 2012 04:49 AM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
falieson
Jan 21, 2010 11:52 PM
takotruckin
Aug 4, 2008 09:07 PM
