Regulator Rectifier help
Old Oct 5, 2012 | 10:25 PM
rsaari13's Avatar
Registered Users
Default Regulator Rectifier help
Okay so I was riding home from school when all the sudden my bike shuts off. Hours later after pushing it home I check all fuses and find that the main 30a fuse is blown. I run up to auto zone get another put it in start it up and my regulator/rectifier starts smoking like crazy. Obviously it's bad now but should
I check anything else first before buying a new one. What could of caused it to blow?
Old Oct 5, 2012 | 10:51 PM
rsaari13's Avatar
Registered Users
Forgot to mention - my battery died 3 days before I trickle charged it and put it back on and it died again the next day so I bought a brand new one and put it on haven't had any troubles from it.
Old Oct 5, 2012 | 11:37 PM
Brandon Henson's Avatar
Well to me it definitely sounds like a R/R issue. The bike shutting off complete and the blown battery definitely indicates that you R/R isn't doing its job. Had a similar issue on my bike a year or so back. R/R went out burned right through brand new battery replaced the battery and looked at my regulator and there was a hole burnt right down the center. But since I believe that it's the regulator can't really give you any more advice at this point but give it till tomorrow I'm sure someone else will give you some detailed steps. Hope everything works out bro and if you do end up getting a new one I'd get the new Honda finned r/r I haven't had a problem with it since.
Old Oct 6, 2012 | 10:37 AM
rsaari13's Avatar
Registered Users
Alright appreciate it bro. How much did you pay for yours and where'd you buy it?
Old Oct 6, 2012 | 12:05 PM
74demon's Avatar
Test your stator and check your wiring/connector. If the stator or a wire is shorted, you will burn up the new regulator instantly.
Check to make sure that the stator pins have continuity to each other, but not to ground. Make sure the wires and connector aren't burned. A burned connector is common...
Old Oct 6, 2012 | 12:17 PM
yeah should have mentioned that during the whole process I ended up having to replace my stator. Check what demon said but if all else fails i bought mine off of amazon for like 60 bucks i believe good luck
Old Oct 6, 2012 | 04:01 PM
rsaari13's Avatar
Registered Users
Alright will do. How do I go about testing my stator exactly.
Old Oct 6, 2012 | 05:35 PM
rsaari13's Avatar
Registered Users
Check the wiring/connected that goes to the R/R? And how do I check the stator exactly?
Old Oct 7, 2012 | 04:49 AM
MadHattr059's Avatar
paul_schmd
May 8, 2010 11:09 PM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
cbrsixpack
The Hurricane Saloon
18
Jan 9, 2010 02:18 PM
shrek
Feb 5, 2008 09:58 AM
jeffrimerman
Dec 22, 2006 03:53 AM
