How much do i shorten kickstand?
Old Oct 27, 2012 | 09:54 AM
Daviator's Avatar
Registered Users
Default How much do i shorten kickstand?
just got a 03 600rr for my girlfriend and i need to put lowering links on it. ive been looking around at shorter kickstands and people want 150$ for them F*ck That!
i cant seem to find anything about how much to shorten the stand though. theres going to be a 1" drop on the bike when im done.
Old Oct 28, 2012 | 07:48 AM
Not that i'm recommending lowering the bike, but that's your call. Provided that the bike is lowered evenly in front and back, then that's about the amount that you'd shorten the side stand. Error on the side of caution. You can always cut more off, but it's harder to make it longer.
Old Oct 28, 2012 | 10:44 AM
MadHattr059's Avatar
Best way to measure...
Cutting the length will NOT be congruent with how much the bike is lowered.
You're dealing with a triangle/rake. Not a straight line measurement.
It's kind of like cutting off an attic-stair.
Measure BEFORE you lower the bike.
Put it on the side stand. Then take a ruler/tape/etc. and holding it vertically on the
ground. move it in on the kick until the amount you are lowering intersects with the
stand. Mark that point. That's what you will be cutting off.
Don't forget to subtract the thickness of the new foot-plate you will be welding back on.
You'll need it, or you'll just be poking holes in the pavement and dumping your bike on it's side, all of the time.
It's do-able, if you have the needed skills, i.e. can weld, other-wise, there's
a reason for the cost of the adjustable replacement stands.
Good luck, Ern
Jeffy_2010
Oct 12, 2012 11:49 AM
BlakeShelton
Nov 1, 2010 04:14 PM
NYKnick1015
May 5, 2010 10:04 PM
206turboballs
F2 Tech
Mar 22, 2010 03:18 PM
Rickracer
Aug 31, 2008 10:33 AM
