higher tail
Old Nov 14, 2006 | 06:56 AM
bowieshum's Avatar
Default higher tail
hi, guys,
i have a 2002 CBRF4I. is it possible for me to raise the rear end about 5mm? and how?
thanks
Old Nov 14, 2006 | 06:59 AM
NINE2NINE's Avatar
Retired Mod
Default RE: higher tail
less preload on the rear shock will raise the rear on your bike
Old Nov 14, 2006 | 12:18 PM
Tahoe SC's Avatar
you can add spacers (thick washers) to the upper bolt that holds the shock to the bike... you'll need lift the rear up by the subframe, pegs, or some other way to take the load off the rear. then go in from under the tank to remove the bolt and add spacers unless you can get in there with very small hands.
Old Nov 14, 2006 | 04:08 PM
dragonium25's Avatar
A rear stand...oh you mean for riding [8D].
LDM
CBR1000F Wanted / Swap
Oct 5, 2013 06:47 PM
WILLS42
Apr 11, 2011 09:58 AM
amig
Oct 2, 2008 09:08 PM
alii121
Jul 14, 2007 07:10 PM
