bogging at higher rpm?
Old Apr 10, 2011 | 04:41 PM
WILLS42's Avatar
Default bogging at higher rpm?
hey i have been having problems with my 98 f3.. it will run fine while sitting there but when you try to ride it and wind it out it starts bogging, i put a piece of tape over the intake half way and it will run better you can go through the gears but at greater rpms it starts bogging and will try 2 cut off... it seems like its running out of gas or something.? could it be the jets or air/fuel set screw?? any help would be great thanks..
Old Apr 10, 2011 | 09:26 PM
Mrmanr's Avatar
Fuel pump working? What kind of air filter do you have?whens the last time you cleaned carbs?
Old Apr 10, 2011 | 10:37 PM
WILLS42's Avatar
well it has a k&n filter on it that needs to be cleaned.. i just took the carbs off, i am going to clean them and make sure none of the jets are clogged, and the fuel pump is a aftermarket one that is working fine, (i bought the bike as a project and it has been messed with a time or two...) but im going to clean the carbs and check ever thing out and see how it goes from there..
Old Apr 11, 2011 | 01:20 AM
Hootie233's Avatar
I think that because it seems to run better when the air is restricted that means that your running too lean I believe.
Are you using a fuel pump?
Old Apr 11, 2011 | 09:58 AM
acidfire52's Avatar
How about your battery? Know a low battery can have troubles with high RPMs.
LDM
CBR1000F Wanted / Swap
Oct 5, 2013 06:47 PM
08600RR
May 10, 2012 10:44 AM
amig
Oct 2, 2008 09:08 PM
alii121
Jul 14, 2007 07:10 PM
bowieshum
Nov 14, 2006 04:08 PM
