higher rpm trouble?
Old Sep 25, 2008 | 11:46 PM
amig's Avatar
Default higher rpm trouble?
hey,
rode my bike to school, had class for about 2hours 45minutes, started her up...then waited at a stop sign behind a car, i loaded the engine (this is where you keep the clutch in the friction zone and give enough throttle so you dont roll down a hill) for a while cause i didnt want to use my brake on a hill...took off and as soon as i hit about 4k my bike sounds like a sv650 and it doesnt seem to be getting the power that im used to its a lot less
when i open the throttle there's it seems like theres noticable lag between throttle and relative movement
anyone have a problem like this
could it be because of me loading my engine?
could it be serious?
anyone have suggestions?
im going to start by checking the spark plugs...
dammit right before my exams too well at least i have the weekend
Old Sep 26, 2008 | 03:22 AM
amig's Avatar
Default RE: higher rpm trouble?
okay looked at spark plugs and they seem fine ill probably pick some up tomorrow just in case
anyone have input into why my bike sounds seems like a two stroke?
ill probably test out the coils tomorrow
Old Sep 27, 2008 | 02:35 PM
amig's Avatar
haha
so my bike is fixed and i have no clue what was wrong
checked everything, coils, wires, spark plugs, timing
and i was like dammit let me just rev the **** out of my bike haha and what do you know the exhaust is sounding the way it did before and it seems to running fine now
weird...
Old Sep 29, 2008 | 02:58 PM
Rickracer's Avatar
You probably just fouled a couple of plugs, and they cleaned back up on their own. [8D]
Old Sep 30, 2008 | 01:38 AM
g32bturbo's Avatar
ORIGINAL: Rickracer
sounds about right. mine sounded like that when one of my coils died (running on 2 cylinders)
Old Oct 2, 2008 | 09:08 PM
elmer's Avatar
Might not hurt to run some fuel system cleaner through the carbs there. Also a new set of plugs would be wise.
LDM
CBR1000F Wanted / Swap
Oct 5, 2013 06:47 PM
WILLS42
Apr 11, 2011 09:58 AM
WildWill
Mar 21, 2009 10:10 AM
bowieshum
Nov 14, 2006 04:08 PM
