higher tail
hi, guys,
i have a 2002 CBRF4I. is it possible for me to raise the rear end about 5mm? and how? thanks |
RE: higher tail
less preload on the rear shock will raise the rear on your bike
RE: higher tail
you can add spacers (thick washers) to the upper bolt that holds the shock to the bike... you'll need lift the rear up by the subframe, pegs, or some other way to take the load off the rear. then go in from under the tank to remove the bolt and add spacers unless you can get in there with very small hands.
RE: higher tail
A rear stand...oh you mean for riding [8D].
