High Idle
Old Apr 2, 2012 | 11:07 AM
jscrogg98's Avatar
Default High Idle
Hello eveyone!
I have a 99 CBR600 F4, and I love the bike.
I just got it a couple of weeks ago, and noticed at a warm idle, its around 2-2.5K The manual idle screw is completely backed off and I have good gas flow, from what I can tell.
The choke lever is opened as well.
Any ideas would be helpful!
Thanks!!
Old Apr 2, 2012 | 03:39 PM
CJardine's Avatar
Track junkie & modaholic
Close the choke.
Old Apr 3, 2012 | 05:24 AM
jscrogg98's Avatar
Cj, the choke is closed
Old Apr 3, 2012 | 05:27 AM
highwaypatrol's Avatar
Once the motor is warm, the choke should be shut off completely. If it is closed and your idle speed is still too high, then it might be that the cables are sticking, either because they need lubricating or because there is no free play in them. You need some free play at the grip so the cable isn't too tight. Adjust the cable adjuster at the throttle to get some slack in it then turn the idle screw until it just starts to increase the idle speed. Check again for slack at the cable. Around 3-5mm is ok. Finally adjust idle screw until idle is around 1300rpm.
Originally Posted by jscrogg98
Hello eveyone!
Thanks!!
Old Apr 3, 2012 | 08:50 AM
david Iligan city's Avatar
hi check check the plugs if black and sooty then choke is not coming off completely if plugs normal check the throttle cables are not holding too high adjust at both ends of cable if ok then maybe the idle jet
is set wrong
Old Apr 3, 2012 | 10:48 AM
jscrogg98's Avatar
Thanks for all of the suggestions!! Since its raining here in Michigan, I will look into this tonight! Thanks again!
Old Apr 15, 2012 | 09:00 PM
jscrogg98's Avatar
Hey all.
Just an update, I found the choke cable loose, at the grip. It was also binding where the tank mounts to the frame, up top.
I still need to order a new one, but its alot better!
Thanks again!
ebag600
Oct 6, 2020 02:08 PM
SPR-GRN
May 7, 2012 06:08 PM
cbr saw
F2 Tech
May 28, 2010 08:58 PM
MrGoats
Jan 23, 2010 08:41 PM
crazycanasian
Dec 21, 2009 08:16 PM
