HELP!!!WONT START
Old Feb 6, 2007 | 12:34 PM
bikerboycbr900's Avatar
Default HELP!!!WONT START
anyone thats has any suggestions that would be great i cant get my bike to start not sure why im not at all a machanic so please post comments in laymans terms my fuel is good, fuel filter is good, plugs only about 500 miles old new oil and filter air filter a little dirty nothing id worry about thought and it is getting spark(the old screwdriver in the plug wire test zzzz) bike only cranks with no intent of fireing as if the kill switch was set to "motor off"its not.How come? please help!!!! phening for throttle.
-----1995 honda cbr900rr---dinosaur fireblade
other then lights NO mods
Old Feb 6, 2007 | 12:37 PM
pawel's Avatar
Default RE: HELP!!!WONT START
Are you actually getting fuel in the cylinders? How do the sparkplugs looks when you pulled them out? Were they wet, cover in oil, black?
Old Feb 6, 2007 | 12:40 PM
a little moist but not dripping
i can smell gad when i try to start it as if i flooding it but even trying to start it without the throttle does nothing
Old Feb 6, 2007 | 01:15 PM
pawel's Avatar
You have to make sure you have a good spark on all cylinders, if you do than do this. Clean the sparkplugs off, make sure they are gapped to specs. Let the cylinders dry out (shut the fuel off and crank the engine for a few seconds, put a rag over the holes casue fuel might spray. Do this about 3 times but let the starter cool so you dont burn it out). Put the plugs back in and try to start it (dont forget to turn the fuel back on). If that doesnt work, take the plugs out again, see if they are really wet, if they are your carbs might be flooding the cylinders. If they are not than you might not be gettign fuel in and than spray some starting fluid in the cylinders, put the plugs back in and crank it. If it starts you are not getting fuel. good luck
supermover25
Mar 15, 2019 08:14 PM
C Jacob W
Jul 29, 2013 11:03 AM
CTcbr929
Jul 31, 2009 12:25 PM
tagger609
Jun 27, 2008 02:09 PM
mishab
Sep 7, 2007 01:00 AM
