Help a nooby brake fluid coming out from under resovoir and oil ?
Old 06-24-2009, 09:42 PM
jamie9002's Avatar
Default Help a nooby brake fluid coming out from under resovoir and oil ?
I changed my oil and filter succesfully on a 05 cbr 600 rr with 3.1 quarts as told looked through the window after it and not even at the middle then went for a ride came back brack fluid dripping from under the break lever when engaged messed up my paint i did take off the cap to the brake resavoir to see if it was full should of looked at the window maybe need bleed now i think there is a buble in the window any advise is apreciated thanks
Old 06-24-2009, 09:51 PM
pacemaker's Avatar
Just taking off the cap should not have put an air in the lines? but anyway, bleeding brakes is not that hard as long as your careful & everything is kept dust & dirt free, using new brake fluid.
There is a lot of stuff on here about doing just that, so do a search. Its probably in need of new fluid anyhow, don't go nuts an over tighten those little brake bleeder valves.
Bad luck about the paint.
Shawn05F4i
08-09-2009 11:47 AM
ThisisMickey
08-24-2007 03:38 PM
buddah
07-18-2007 06:38 AM
blade8r
07-14-2007 01:21 PM
gruntworker
10-04-2006 10:44 AM
Quick Reply: Help a nooby brake fluid coming out from under resovoir and oil ?
