Help a nooby brake fluid coming out from under resovoir and oil ?
I changed my oil and filter succesfully on a 05 cbr 600 rr with 3.1 quarts as told looked through the window after it and not even at the middle then went for a ride came back brack fluid dripping from under the break lever when engaged messed up my paint i did take off the cap to the brake resavoir to see if it was full should of looked at the window maybe need bleed now i think there is a buble in the window any advise is apreciated thanks
on
1 Post
Just taking off the cap should not have put an air in the lines? but anyway, bleeding brakes is not that hard as long as your careful & everything is kept dust & dirt free, using new brake fluid.
There is a lot of stuff on here about doing just that, so do a search. Its probably in need of new fluid anyhow, don't go nuts an over tighten those little brake bleeder valves.
Bad luck about the paint.
