having trouble down shifting
Old Apr 4, 2011 | 06:48 AM
drag900's Avatar
Registered Users
Default having trouble down shifting
Hey there, I'm new to the site and have a question. I have a 98 and i'm having trouble down shifting, the bike upshifts fine all the time. When the bike is cool it seems to down shift fine but when it gets hot then i have trouble down shifting. I have replaced the shift forks and the gear shift drum. Went for a ride around town the other day and after awhile it had trouble shifting. Now i'm wondering if it could be a bent shift shaft. Any help would be appreciated.
Old Apr 4, 2011 | 09:41 AM
highwaypatrol's Avatar
Hi. I haven't had much experience with modern clutches, having had many British bikes, but they all work in a very similar way. I would check the clutch adjustment first before spending any more money on your bike. As an engine gets hot everything expands as you probably know and if the clutch plates aren't disengaging properly you willl get clutch drag whereby the clutch plates don't free off properly. Another cause is a worn clutch basket that stops the plates from sliding in their grooves. Usually though, this causes problems changing up and down. If getting the adjustment right doesn't sort out your problem then I guess other members will! Great bunch of knowledgeable guys in the club!
WildWill
Mar 21, 2009 10:10 AM
rustler84
Jan 26, 2009 01:28 AM
terror
Sep 23, 2007 12:47 PM
Ciao Fun
Jun 21, 2007 01:26 AM
c.love220
Nov 22, 2006 12:03 PM
