hard to start, mostly mornings
Old Feb 9, 2009 | 08:48 AM
SkoogusMaximus's Avatar
Default hard to start, mostly mornings
I have a 2003 f4i and I've been having trouble getting it started if it sits for too long. Every morning i have to hold the starter button for what seems to be forever to get it started. A few weeks back it took almost 2 minutes and some throttle play to get it going.
Once it does start, it takes about 5 minutes for the idle to get to where it needs to be and sounds like garbage until then. My FI light blinks twice every once and a while but i'm pretty sure the manual said thats a loose wiring problem or something. Any thoughts? Is this close to normal?
Edit: When the problem started i poured a little Sea Foam in the gas tank but it didn't seem to fix the starting problem.
Old Feb 9, 2009 | 09:39 AM
Todd84's Avatar
My F4i developed the same problem. Change the plugs. I did that and didn't have any problems after that. I also changed the air filter while everything was off. Go with BMC. The plugs are expensive so just brace yourself when they give you a price.
Old Feb 9, 2009 | 09:14 PM
Tacoma25's Avatar
It sounds like fuel pressure regulator issue. The pressure bleeds down quickly and causes hard starts. Try the plugs first, but What you stated is a tell-tale sign from past members.
katodapitbull
Mar 10, 2025 08:17 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
JayBoCC2
Jun 23, 2009 10:23 PM
motorbyte
Nov 23, 2007 11:32 AM
Flamed900RR
Apr 25, 2007 10:50 PM
