hard landing on forks
Old Jul 28, 2009 | 04:57 PM
super600's Avatar
Default hard landing on forks
just got my 01 F4i about a month ago. i just replaced the fork seals because one was leaking. it all went together right and felt good and smooth while riding but recently when i get on the front brake it feels like it wants to pull slightly to the right and it shudders a little which i think could be the rotor? but why is it pulling to the right?
also the other day i was out riding and clutching up in 1st gear just getting a feel for the power. i have been doing good but the last one i set down kinda hard and the front wheel went up and took out the front fender and cracked my right side fairing. is there anything i should inspect for any other damage then the fairings?
Old Jul 28, 2009 | 05:44 PM
sbf916's Avatar
sounds like ur forks werent done right dude, meaning wrong weight or amount. way 2 soft if it bottomed out completely and wacked ur fender, that sucks. take em off and have ur local shop redo them or if u did have a dealer do it take it right back an get it fixed cuz thats there fault. brake chattering might b if ur rotors are grooved to $h1t or pads down, or might jus need the whole brake system flushed with new fluids. bad fluid =bad brakes an improper working master cylinder, inconsistent pressure to the calipers might b the pulling right feeling. hope this helps.
Old Jul 28, 2009 | 07:38 PM
super600's Avatar
thanks bud,
i did the forks my self. my service manual said to put 8oz of fluid in each. i was confused because when i emptied the right fork there was 12oz in it? im confused why there would be more than what the manual says to add.
i will take them apart and redo them i suppose. does anyone have any input on fluid level or how to stiffen them at all?
Old Jul 28, 2009 | 10:42 PM
mikey49's Avatar
There is a good write up on rebuilding front forks by rabbit. Check it out.
mikey
https://cbrforum.com/forum/how-mechanical-40/how-rebuild-your-forks-f4-f4i-41756/
omg209
Jun 8, 2012 03:51 PM
TheX
Oct 20, 2008 10:04 PM
jfunkRR
Apr 30, 2008 09:23 AM
iceman3ar
Apr 3, 2007 01:33 AM
VP
Jan 4, 2007 01:53 PM
