General Maint
change the brake fluids, lube/adjust the chain, flush the coolant, check tire pressure and condition (look at the date codes [replace if older than 6 years] tread depth and sidewall/stem for cracks) set the suspension for your weight and riding style, light bulbs, and check the torque on every bolt you can get to. a good, deep cleaning will reveal quite a bit of corners that were cut by the PO as well as missing or loose bolts.
good luck and enjoy your new ride!
demon
demon
Sprock
The Hurricane Saloon
29
08-03-2013 09:30 PM
