Fuel pump on 600F1
Old Nov 3, 2024 | 04:15 PM
T-38FAIP's Avatar
Default Fuel pump on 600F1
Can someone please explain when the fuel pump on a F1 600 originally should turn on when you wake the bike up? I expected the pump to start to prime once the ignition is turned on and the kill switch is in run. I don’t here any noise from the pump until I actually engage the starter, the bike is running fine, I’m just trying to understand the logic behind how it works.
Thanks a bunch
T-38 FAIP
Old Nov 3, 2024 | 04:52 PM
Ed Harris's Avatar
Thanks a bunch
T-38 FAIP
If it's a 1987 to 1990 F1 then it's carb and, as long as the bike's been used recently and the float bowls are full, the pump won't cut in until the engin's started and is using fuel.
If it's a 2001 F1 then it's ?injected? and the pump will cut in as soon as you wake the bike to pressurise the fuel line.
Old Nov 3, 2024 | 05:22 PM
T-38FAIP's Avatar
It’s a ‘90. I don’t think the carb bowls were full, and I even had the fuel turned off. That’s why it piqued my interest. I went down a rabbit hole and did some testing with the multi-meter. I thought I had a bad kill switch or fuel pump regulator. I ordered and installed a new regulator and nothing changed. Unplugged the regulator and jumped the wires straight from the ignition and the pump turned on (I was hoping it would so I wasn’t looking at a new pump). Just the fact that I don’t think the bowls were full and I wasn’t getting any action on the pump had me concerned.
Old Nov 3, 2024 | 08:28 PM
Ed Harris's Avatar
Does the bike run ok?
If so, don’t overthink it :-)
Old Nov 8, 2024 | 07:46 AM
tomi's Avatar
The fuel pump is not activated by simple ignition, but rather when the starter is engaged. This helps prevent unnecessary wear on the pump and improves safety in the event of an incident. The pump activates to force fuel into the system the moment you start the engine.
Old Nov 8, 2024 | 03:37 PM
T-38FAIP's Avatar
Thanks for taking the time to explain that, I do appreciate it.
T-38FAIP
Old Dec 3, 2024 | 03:13 PM
romaissa's Avatar
On a Honda CBR600F, the fuel pump primes for about 2-3 seconds when you turn the ignition key to "ON" to pressurize the fuel system. It stops after that unless the engine is started. If it doesn't prime, there may be an issue with the fuel pump relay, fuse, or wiring.
Old Feb 17, 2025 | 11:51 AM
accentoldman9's Avatar
Default bike
Old Feb 17, 2025 | 03:43 PM
T-38FAIP's Avatar
Bike absolutely runs fine, I was just interested in understanding what was happening in a normal operating situation.
Ricebiker
Feb 26, 2017 09:21 PM
Timbostang
Nov 18, 2011 09:37 AM
CSXfan
Mar 7, 2009 07:11 PM
madmike01uk
Aug 23, 2007 06:48 AM
SIRR1
Sep 13, 2006 02:55 PM
