fuel pump
Old Jan 24, 2011 | 02:48 PM
LJ Harp's Avatar
Official CBRF Decal Man
Default fuel pump
Im 99.9% sure I don't have one, what my bike uses is a petcock and runs off the vacume. Reason I bring this up is I hear the term fuel pump alot and was wondering what bike models and years have one. Or did my bike at one point have one and then someone removed it?
96' 900RR
Old Jan 24, 2011 | 02:56 PM
CBRfenatic93's Avatar
Honda didnt start putting EFI on the 900's till the 929 came out in 2000.
Old Jan 24, 2011 | 03:24 PM
LJ Harp's Avatar
So in order to have a fuel pump you have to have EFI? That's what I thought too but my buddys F1 has a fuel pump or what I believe is a fuel pump?
Old Jan 24, 2011 | 03:30 PM
I remember reading some threads in the F2 section about people buying a fuel pump and modding their bike to take it. So i guess you dont have to have EFI to take a fuel pump. I guess it just comes down to looking and seeing what the persons bike has.
Old Jan 24, 2011 | 03:33 PM
LJ Harp's Avatar
So its not really needed unless you have EFI. Thanks Chris knowledge is power.
Old Jan 24, 2011 | 04:23 PM
stretch_the_apex's Avatar
my 2000 f4 (carbed) had a fuel pump most sport bikes do have fuel pumps my buddys f3 had one, fuel will still get to the motor without one but its optimum with one. when you start doin mods like exhaust or airfilters etc the bike can start to sputter under load from lack of fuel
Old Jan 24, 2011 | 04:31 PM
justasquid's Avatar
a lot of carbed bikes use fuel pumps. Fuel injection has nothing to do with whether or not a bike has a fuel pump. You will see some models of cbrs have fuel pumps, then a year or two where they don't, then they go back to them. they varied throughout the years. It all comes down to the design the bike. If the tank has a low petcock, and high carbs, they will use a fuel pump. This being that the carbs are to close to parallel with the petcock and the fuel doesn't flow fast enough to keep the carbs filled. If you accel fast enough, you can run the carbs out of fuel as the gravity can't keep up. On some models, the distance is far enough that fuel pump is not needed. Even though there is a fuel pump on some models, they are very low psi. Generally, they are only 1-2 psi and act as an assist more so than a fuel pump. Thats why on some models like the F3, the fuel pump can be removed and the bike will still run ok with a full tank of gas and normal driving.
But your right. the 96 doesn't have a fuel pump. it runs off vacuum. If you search enough, you can find people that have swapped other fuel pumps in place of the vacuum. But if its working, theres really no need to make the swap.
Fuel injected bikes require high pressure fuel pumps. thats the only difference.
Old Jan 24, 2011 | 07:33 PM
asides's Avatar
f1's do i belive f2's no f3's yes on the fuel pumps
Kopi Ko
Sep 6, 2024 12:02 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
Fool
F4i - Wanted
May 10, 2010 02:05 PM
zblad
Dec 5, 2008 01:14 AM
