fuel cut off relay question
Old 02-01-2010, 10:42 PM
marcusa's Avatar
Default fuel cut off relay question
I have a 93 CBR 900RR and found out my fuel cut off relay is bad. Does anyone know if this relay has any important function that I should spend the money to replace it or can I just wire my bike to bypass this relay?
Old 02-02-2010, 04:43 AM
justasquid's Avatar
Im not 100 percent sure, but I don't think you can just bypass it.
You certainly couldn't use the power supply that triggers the relay, as that is simple a signal voltage and not enough to supply the fuel pump. Also, I think the cut relay actually operates the fuel pump to kick on and off, even while the bike is running. I don't think the fuel pump contiuously runs the entire time. It turns off and on as pressure is needed. If you ran a wire directly to the pump, I think you would burn it up.
Old 02-02-2010, 05:05 AM
Kuroshio's Avatar
You can bypass the cut off relay, as that's part of diagnosing the fuel pump. But pretty sure it's not a good idea for the reason stated: pump isn't supposed to run constantly. Only when needed
Old 02-02-2010, 08:32 PM
marcusa's Avatar
Ok, cool, thanks guys.
Old 02-24-2010, 09:46 PM
qwarnon's Avatar
if its like my 07 cbr, then that relay is the exact same as all the others, it should be simple to find a new one and replace
jag007
04-22-2013 08:49 PM
exodus191
11-29-2010 11:24 AM
building
10-21-2010 05:43 AM
collarbone
07-29-2009 08:30 AM
Quick Reply: fuel cut off relay question
