front wheel removal
Old Mar 8, 2010 | 12:49 AM
dise0416's Avatar
Default front wheel removal
How do I take off my front wheel on my cbr 600 f2 and what tools do i need? Thanks
Old Mar 13, 2010 | 03:30 PM
UK_Jase's Avatar
did this 2 days ago.........
1. use track stand on front forks if you have one or take weight off front however - cannot just leave on centre stand
2. remove both calipers (2 bolts on each)
3. loosen main front wheel bolt - dont remove yet
4. loosen 2 bolts on each fork tube at bottom - do not remove
5. remove main wheel bolt - care to remove speedo mech when removing wheel
6. remove bearing spacers from each side and all done
NOTE - using a block of wood under the wheel can make removal/assembly much easier
Hope this helps
Jase
Old Mar 14, 2010 | 09:22 AM
skoobydoobie's Avatar
if you don't have a stand, a ratchet strap will work. Just wrap it around the triple and hang it from the rafters. (assuming you have a garage)
Old Mar 14, 2010 | 11:58 AM
CBRfenatic93's Avatar
You know. I had to replace my speedometer drive 3 days ago and thought about making a walkthrough on how to take the front wheel off as well as replacing the speedo drive. Ended up not doin it thinking no one would use it and now i regret it. lol sorry bud
deucea
May 17, 2022 02:16 AM
creaturecore
Jul 15, 2011 04:35 AM
whtan20
Jun 26, 2008 04:23 PM
dwhite645
Jun 20, 2006 12:27 AM
ModifiedCBR600F4i
Sep 30, 2005 09:41 AM
