Flushing Cooling System...?s
Old Aug 29, 2006 | 11:29 AM
  #41
mikequinn's Avatar
Default RE: Flushing Cooling System...?s
who cares?????
run what you like.... we seem to do great over here
Old Aug 29, 2006 | 06:03 PM
  #42
canadianF4i's Avatar
Worried you might make some enemies on the board by your unedited post does this sound familiar ?
"what a tosser you really are!!! your the stereo typical yank/canadian know all bigger and better than anyone else"
What a wus! afraid to say what he thinks because ppl might not like him.[sm=bustedsign.gif]
All I was trying to point out is; I am not some wet behind the ears mechanic working in some back woods shop. With all the training/experience I've had I also think I have a pretty good understanding of engine operating basics such as cooling and oiling systems you arrogant ***. It is you that was bragging about your education and how the trade is going to **** because only guy's like you know anything and how you even have letters behind your name. Well I got some more letters to add BS and FU.
Old Aug 29, 2006 | 07:11 PM
  #43
mikequinn's Avatar
ORIGINAL: canadianF4i
grow up you silly little BOY!!!!!!!
You really are dim aren't you can't weight up weather your JUST in or JUST Out
Old Aug 29, 2006 | 08:42 PM
  #44
Whatever ![sm=loser.gif]
Old Aug 30, 2006 | 08:00 AM
  #45
mikequinn's Avatar
maybe as your so clever ! you mentioned "piston slap", can you clarify just for the readers and members of the Forum what effect "piston slap" has on the bores especially at low temps'????
And you'll be familiar with the term "Cold Seizure"???, then the forum can decide weather cool running accelerates bore wear,
thought I'd just let you dig a big hole for yourself berore you burried yourself.........
Old Aug 30, 2006 | 11:15 AM
  #46
I can't believe I'm even bothering with you anymore. But since you probably went to work (if your not already retired) and asked your co-workers to give you some ammo because you're being made a fool of by some canadian mechanic on the internet or frantically dug out a book and/or racked your brain trying to come up with something I'll humour you. By the way, if there is anyone else on here that's thinking this is getting tired just let me know and I'll stop playing with this tool but since I'm bored I'll continue.
Over time/use "piston slap" will cause the engine bore to become "egg shaped" with more wear on the thrust side of the bore (and piston). It is more evident when the engine is cold because the piston expands when hot and will fit tighter in the bore and so there isn't as much room for the piston to move side to side or "slap" if you will. It is more common with inline engines because the con rod is almost directly over the crankshaft so when it fires the force of the explosion drives the piston not only down but sideways into the wall of the bore because of the rotation and location of the crank. A V-shaped engine isn't affected as much because the pistons are at an angle to the crank and so there isn't so much sideways force. I apologise to those of you that aren't familiar with engine configurations, I know my description is not very good but it's hard to describe without a visual aid and not really important to the answer anyway. Which is; "piston slap"/bore damage is not caused by running an engine cold the cold engine only amplifies an existing problem. The cause is usually engine wear (normal or otherwise) or by poorly matching pistons to bores when assembling the engine.
I'm not familiar with the term "cold seizure" is that a british term? Notice I admit when I don't know something, but if you tell me what it is I'll explain to you why it happens. How bout that?
Now it's my turn, I have a question for you.
What is it you're trying to prove anyway? The importance of using the proper coolant, we've already determined that. Or are you so insecure that you have to keep quizing me so eventually you can say "AHA! I told you guys I know something he doesn't know"? Or is it you're retired sitting at home feeling old and useless and want to prove you "still got it"? Well let me save you the trouble, I'm sure there is stuff you know that I don't but this isn't it and quite frankly I'm surprised that you are even arguing about this. Your trying to compare a specific application, the UK motorcycle race circuit engines and what they do to North American street use and there is no comparison. I am simply talking general engine theory and of course there are exceptions to the rule. I was only trying to give these guys the basics of engine cooling theory(in case they didn't already know) so they could draw their own conclussion. But for some reason you can't just let it go you keep coming back with "well what about this or that" who the hell cares! If someone asked a question because they didn't know and wanted help that's one thing but you're just trying to compete with me which is retarded. Instead of just saying "your a tosser" or "grow up silly boy" why don't you try explaining why I'm wrong in an intelligent way. If you know as much as you would lead us to believe that shouldn't be too difficult for you.
Old Aug 30, 2006 | 12:32 PM
  #47
Tahoe SC's Avatar
hey you two...better chill...this board isn't for personal assaults ok?
you've both provided great information and your experienced/educated and valued opinions for others to make an inform decision...and if they have any questions, they can decide the rest for themselves...
so please...move on...
Old Aug 30, 2006 | 01:01 PM
  #48
mikequinn's Avatar
Although this post has made for good reading..... can't be botherd with this canadian tool
Old Aug 30, 2006 | 06:20 PM
  #49
yipperzz's Avatar
hahahahha rofl good job rrasco look what you started with this post
Old Aug 30, 2006 | 06:31 PM
  #50
No problem Tahoe SC.
As you can see from mikequin's last post it was getting to be a waste of time anyway.[sm=headbang.gif]
