Flushing Cooling System...?s
Old Aug 28, 2006 | 09:54 AM
  #31
canadianF4i's Avatar
Default RE: Flushing Cooling System...?s
My mechanical experience is with cars and heavy trucks (I'm a licenced auto and commercial transport mechanic) not bikes but the principles are the same and there were a few incorrect statements made by mikequin.
Lowering your operating temp by any amount will not harm your engine or increase wear it will only affect your engines efficiency. If that were true you'd be excessively wearing your engine from the time you started it until the time it got to operating temp. The only time temp plays a role in engine wear is when your oil is too cold to flow properly and the bearings, etc, are starved for lube or too hot and it breaks the oil down so it doesn't lubricate as designed.
I'm not sure how water pumps are designed on bikes but in cars and trucks water pumps do benefit from conditioners which are built into the coolant to help keep seals pliable so they don't leak. I think this is what Tahoe SC was refering to when he wrote "lube" so technically you're right mikequin it isn't lube but I can understand how Tahoe SC might make the connection and in Water Wetters literature it says "cleans and lubricates water pump seals".
Water Wetter's claim is that it will lower your operating temp by up to 30 degrees because of approx 50% better heat transfer over a water and glycol mix. The reason they advertise this is for drag racers that are running smaller rads or possibly without a fan so they can run cooler longer and enable them to run more timing advance without detonation. Water Wetters boiling boint is actually lower than a water and glycol mix but can be raised by using a higher pressure rad cap. If I remember correctly 1 psi = approx 3 degrees higher boiling temp or something like that.
It makes me laugh when the guys that have been turnin wrenches for "26 years" or so think that if it's not the way they know or were taught it can't be right and they're never wrong. Well guess what ?[sm=icon_rtfm.gif]
Old Aug 28, 2006 | 01:07 PM
  #32
mikequinn's Avatar
ORIGINAL: canadianF4i
You really need to go back to college, and stop givin incorrect advice and read the book yourself..... you are slowly wearing the parts in the engine at cool temp's thats why it has a stat in it to get it up to optimal temp....The oil & coolant both play an important roll.....Thats also the reason you don't kick the *** out of engines from cold,
when racing and drag racing the engine is revved that hard the temp comes up too quick thats why they remove the stats or they would overheat
Iv'e been a mechanic for the UK HONDA British Champion for the last 8 yrs so i think I know what I'm talking about.
Don't forget what's learned on track at this level is also transfered to proddy bikes like the one's your riding now....
Old Aug 28, 2006 | 01:51 PM
  #33
Err's Avatar
Err
well i'm not gonna read all that, but i use engine ice (they have a premixed **** out now, needed 2 for my 900) and that **** keeps my bike cool as ****, and i'm in a lot doing wheelies for hours. it claims to drop the temp by 50 degrees, i don't have a temp gauge so i can't tell you precisely how much it drops it down. but you will notice a difference...
never used water wetter though
also i just used distilled water when i flushed my system, i flushed it 3 times with the water. never knew about the vinegar....
Old Aug 28, 2006 | 05:11 PM
  #34
Ocelaris's Avatar
Wouldn't running straight water be detrimental to aluminum etc...? I remember having a liquid coold refrigeration system, where the aluminum evaporator sprung pinhole sized leak so the refrigerant started to spew out... So I plugged the leak, and used ethylene glycol (green stuff) and made sure it was aluminum safe.
Wouldn't the anti-corrosive properties of anti-freeze be beneficial? That alone would be a reason to use it, at least in some small quantities.
I would be worried about running straight water, especially distilled since it has no buffering capabilities of it's own. I think it would get very acidic very quickly...
They use watter wetter in PC liquid cooling systems also quite often, and they aren't anywhere near boiling temps, maybe 5-10*C above room temp... so I am not totally buying into the surfectant (sp?) theory. I haven't heard anything I buy into as of yet, but it doesn't seem to hurt either. I'll wait until I read some more before passing judgement.
If you consider anti-acid pH buffers which inhibit the breakdown of rubber/silicone type seals a "lube" I guess it could qualify...
Maybe I don't understand the whole point of Anti-Freeze...
Old Aug 28, 2006 | 06:11 PM
  #35
mikequinn's Avatar
use what you like!!! Distilled water is pure that why it has gone through the distilation process there is nothing other than pure water. Honda recommend it, I have used it for numerous years never had a problem with a cooling system yet on Motorcycle,
I really couldn't care less what you use, if you want to f**k up your prides and joy go ahead, and use straight water what do i know??
Old Aug 28, 2006 | 06:43 PM
  #36
rrasco's Avatar
ORIGINAL: mikequinn
i think he was more or less asking, and weighing factors....no need to be harsh here, anyone.
Old Aug 28, 2006 | 07:38 PM
  #37
[sm=bs.gif]Actually the reason you don't "kick the *** out of engines" when they're cold is because engine parts are designed with specific tolerances ie pistons to cyl block and because metal expands with heat these tolerances are greater when cold than hot. For example, if you were to rev the **** out of your bike, etc, when cold especially under load, you would or might get some piston slap, which over time would gradually get worse because of the piston "hammering" the cylinder walls (same idea with bearings). It has nothing to do with engine wear and everything to do with engine damage.
Having said that, todays engines are built with such small tolerances and similiar metals ie aluminum pistons and blocks that expand and contract at similiar rates so even when cold you are not likely to damage anything. Not to mention, think about the temp inside the combustion chamber when running and the RPM involved especially on today's engines, parts get hot quick. Personally I still would not rev my engine until about 150 degrees or so on the gauge but that's because there is no way of knowing how much wear the engine has or the tolerances and to ensure the oil is up to temp and protecting engine parts as designed. Bottom line is engines wear no matter what you do all you can do is maintain them and run a good quality oil and change it as recommended.
You are right about the thermostat being there to get to operating temp quicker but your reason is incorrect it's because the engine is designed to run more efficiently at operating temp resulting in fewer harmful exhaust emissions. Again nothing to do with engine wear. Racers don't care about emissions so they may not bother with thermostats or run with a hi flow one set at 165 degrees so they can run more timing advance, etc on a cooler engine and therefore make more power.
Just to clear this up, coolant has nothing directly to do with engine wear it's only purpose is to help control engine temp. It is the lubrication system that reduces engine wear coolant only helps keep the oil at an effective temp. Perhaps mikequin can explain to us why there are so many choices of viscosity of oil. So far as coolant Honda recommends "Pro Honda HP coolant or an equivalant ethylene glycol antifreeze containing corrosion protection inhibitors" at a "50% mixture with soft water" as do most manufacturers. Obviously if you were to race you would need to use Water Wetter or similiar for the safety of other riders/drivers and to comply with the rules but for any other time regular antifreeze would do the job just fine.
Like I said before mikequin you're knowledge is based in the past when blocks were cast iron and the metals that were used in the engine were less compatible. Maybe it is you that should go back to school and throw away your 30 yr old text books and join the rest of us in 2006. I'm guessing your 8 yrs with Honda racing was in the 80's because so far I have heard nothing that a recent Honda racing tech would say that or you've been misinformed for a very long time.
Anyways I'm done trying to explain this to mikequin as most guys like him are so pig headed no matter how many times you prove to them they are wrong they still don't believe it. I recommend you guys look up some recent engine cooling and lubrication theory (car or bike doesn't matter principles are the same) and find out for yourselves because opinions are like ******** everyones got one.
Old Aug 28, 2006 | 08:40 PM
  #38
Ocelaris's Avatar
Thanks for the good information, especially about blocks, sheds some light.
Old Aug 29, 2006 | 07:27 AM
  #39
mikequinn's Avatar
you really need to show some respect you little *** wipe, grow up and read your text book, then come back when your more informed on hondas, you probably only spent 2 - 3 yrs learning your trade, where as I had 4 yrs learning my trade, + 2 yr taking my diploma giving me letters behind my name Bc.Mec,Sc...... thats why the the trade is going belly up because people dont know what they are talking about ...& I never stop learning, & you have heard this stra
Old Aug 29, 2006 | 09:22 AM
  #40
If you deserved respect I'd give it but your just a know it all blow hard who likes to flex his brain on things he thinks he knows about.
For the record I spent 1 yr in a pre-apprenticeship program followed by 6 weeks of full time school every year for 3 years while I worked in the trade for a Chrysler dealer until I recieved my red seal for automotive repair. Then 3 years later I had the opportunity to sign up for the commercial transport mechanic apprenticeship and went to school for 6weeks a year for 4 yrs while I worked in that trade until I got my red seal for that as well. I also have my AirCare certificate (emissions), A/C certificate, and my vehicle inspectors certificate. But then again how could I possibly know as much or more than you, your a Honda bike mechanic so that trumps all my training.[sm=hail.gif] And yes I realize none of my training is on motorcycles but the priniples are the same no matter the application.
So far as what your allowed to run in your cooling system on the UK race circuit, who cares it's not relevant. The question was about Water Wetter in a street application, which also happens to be allowed on the North America race circuit and does a better job than water alone regardless of use (race or street). Also I don't see the relevance of the fact you tear down your race engines after every race, what do you want a cookie, we were discussing street applications and in the Honda manual it states to use a 50% mix of ethylene glycol and water which is what most manufacturers recommend.
Look! I think we've beat this to death, you've posted what you think to be facts and your opinion on the subject and so have I so just let it go. I'm sure the others on the forum will decide what or who to believe or perhaps they have their own ideas either way I'm done going back and forth on this with you.
Since you never stop learning why don't you learn; you don't know as much as you think you do and to stay on topic.
