Flushing Cooling System...?s
Old Aug 24, 2006 | 06:50 PM
  #21
mikequinn's Avatar
Default RE: Flushing Cooling System...?s
If your lowering the runnin temp your accelerating engine wear ,FACT anyone with any mechanical savvy will tell you all engine wear is caused before the engine reaches it's optimal temp' so why lower the temp, thats another myth, what "water wetter" mean is it raises the boiling point. Just like eythol antifreeze, does exactly the same thing
yes i did copy and paste the script, but you said it lubs', lubs what???????? there' s nothing to lub' in the cooling system
next you'll be telling me you put it in the cental heating system of your home to lube the boiler what aload of trash!!!!
and while your at it lub the taps on the basin too hahahahahahahaha,
realisticly they are gimmics just like so called octane booser
distilled water and antifreeze 50/50 will last you longer and you'll have no problems with your cooling system.. oh and it's cheaper toooooooooooooo!!!!
Old Aug 24, 2006 | 06:52 PM
  #22
mikequinn's Avatar
you actually saw inside the water jacket of your cooling system with you own eyes????????
if I could do that I would have made a million by now, in preventative maintanance
Old Aug 24, 2006 | 07:28 PM
  #23
yipperzz's Avatar
ORIGINAL: mikequinn
most tracks won't allow you to run with antifreeze. and how cheap are you where you can't afford a 7 dollar bottle that lasts forever? since you've been in the business for that many years, i'm sure you make enough money where you can buy 1 bottle. it's not like octane booster where you throw in a whole bottle and then you have to buy a new one when you're done. you put in a few CAPS in and you're done.
here's an article from a guy with a phd in heat transfer. he addresses your statements about lowering running temps and increasing the boiling point
http://e30m3performance.com/myths/mo...ter_wetter.htm
everyone can argue all day and i'm sure it won't change your opinion on this. so that's all i have to say... you guys can use whatever you want. it's not my problem. just don't crash in front of me on the track if you're running antifreeze.
Old Aug 24, 2006 | 08:22 PM
  #24
Tahoe SC's Avatar
ORIGINAL: yipperzz
it doesn't matter mang...because you don't need spilled antifreeze to make you crash at the track...LOL...
actually water wetter is like $7 for 12 oz...you use roughly 4 capfuls for the whole cooling sytem...so it can last you a long long time...distilled water is very cheap. so together, much cheaper than coolant.
no you don't run it if you live in freezing climate areas.
i'm not a mechanic, i'm an avid enthusiast...i get my tricks, info, etc. from riders, racers and other DIY people. but i know enough to take great care of my bike...and a 40K, she still runs strong and great...only cooling problem i've had has been attributed to air bubbles and busted cooling fins...
how about i send you the rest of yipperzz bottle to test it out? i don't think you've ever tried it...ever...so why not run it and see what it does for you before you bash it?
i won't tell you what to do to your house or anything of the like...i really couldn't care less...
yes octane booster is a load of crap...i agree with you there.
Old Aug 24, 2006 | 08:39 PM
  #25
yipperzz's Avatar
ORIGINAL: Tahoe SC
ORIGINAL: yipperzz
you're a bastard...
but yeah. i already crash on my own, so don't give me another reason to crash.
and save me a few cap-fuls for the new bike and i will gladly donate the rest of my bottle to him to try out.
Old Aug 25, 2006 | 01:39 AM
  #26
rrasco's Avatar
so tahoe and yipperzz, you guys only use the water wetter? or do you live in freezing climates and switch to antifreeze in the winter?
Old Aug 25, 2006 | 02:32 AM
  #27
Tahoe SC's Avatar
no, we're in socal, just water and water wetter.
regardless of what you choose to use, just make sure you make and informed decision and be very indifferent with it until you see it for yourself as to what works and what doesn't.
Old Aug 25, 2006 | 02:35 AM
  #28
yipperzz's Avatar
if you live in cold temps i wouldn't use what we do. it never gets colder than 65 out here. i've never used engine ice before but if it doesn't freeze, that could be a good alternative. even water/antifreeze/ww can still be cooler than water/antifreeze alone.
Old Aug 25, 2006 | 06:45 AM
  #29
mikequinn's Avatar
ORIGINAL: Tahoe SC
yea water wicks away heat the best but water itself doesn't have the nice lubricating properties that WW provides...so i'd use some water wetter with it as some cheap insurance...or else your seals and sea lions in your system and other stuff that need some lubricating may be hurting later.
seems like we've gone off track here, the whole reason this argument / debate went on was because of this quote saying it was a lube' for the cooling system! and it isn't
each to there own use what you like for me i couldn't care less
i'm only offering my advice & experience,
Old Aug 25, 2006 | 11:41 AM
  #30
rrasco's Avatar
ORIGINAL: yipperzz
well, im in south texas, as it normally doesnt get cold very long, when it does, we can get well below freezing, so i guess when that comes around ill put the engine ice in, sounds like water wetter ill be using for now, thanks again guys...all of you.
