first time carb sync help
Regardless of where the vac hose is (I assume it leads to the petcock shut-off),
you're gonna need to remove all of the manifold screws/nipple-covers.
The sole purpose for them is to allow you hookups for the sync-gauges.
You may need more or less adapter nipples to screw into their places
(so you can connect the vac-guage hoses). Normally, Honda uses 5mm adapters (I believe).
Use the barbed hose adapter(s) the same size as the screw(s) you removed.
You don't remove the screws on the carb-bodies, you adjust the vacuum with them.
The body without an adjustment screw is usually the base carb, so you adjust to it.
In this case the #3 (according to the manual above).
I would replace the o-ring you lost. Try a hardware or auto-parts store,
bring one, off of another pilot screw, to match up.
Hope this helps with the confusion.
