FI Light on after bike is turned off
#41
RE: FI Light on after bike is turned off
This is much easier to do in Daylight.
(Black Connector, tested with the Red Lead connected to the battery, and the Black Lead on the connector)
Black Wire w/Brown Stripe: 12V
Green Wire (Solid): 12V
(White Connector, tested with the Red Lead connected to the battery, and the Black Lead on the connector)
Green wire w/Blue Stripe: 11.5V
#42
im at work right now. when i get out we'll continue. your blk/brn wires should be 12v with black lead grounded and probing with red lead.
you said you checked your fuses. are there 6 or only 4? pull them all and double check for burned fuses. they should be red 10 amp fuses.
talk again in a few hours.
dewthedoo05
09-04-2007 09:32 PM
