Fairings, how tight?
I have a bad vibration noiseat 5-6k rpm and I figured it was because I left the front two fender screws loose after I removed the front reflectors. I have trouble tightening them down because now with the reflector bracket gone, the rubber grommets squish out more then they seem they should.So I tightened them a bit more while I wait for you guys to tell me if you have the same issue.
I decided to check the other fairing screws as well and found the windscreen ones loose, and all the others that were plastic on plastic. I gave them a few turns, but did not tourqe on them because I dont want to crack anything. How tight should they be? The screws that went into the frame were plenty tight.
Thanks!
Drekkyk
07 CBR 600 RR
I decided to check the other fairing screws as well and found the windscreen ones loose, and all the others that were plastic on plastic. I gave them a few turns, but did not tourqe on them because I dont want to crack anything. How tight should they be? The screws that went into the frame were plenty tight.Thanks!
Drekkyk
07 CBR 600 RR
