Fairings, how tight?
Old Jun 18, 2007 | 11:38 PM
Drekkyk's Avatar
Default Fairings, how tight?
I have a bad vibration noiseat 5-6k rpm and I figured it was because I left the front two fender screws loose after I removed the front reflectors. I have trouble tightening them down because now with the reflector bracket gone, the rubber grommets squish out more then they seem they should.So I tightened them a bit more while I wait for you guys to tell me if you have the same issue. I decided to check the other fairing screws as well and found the windscreen ones loose, and all the others that were plastic on plastic. I gave them a few turns, but did not tourqe on them because I dont want to crack anything. How tight should they be? The screws that went into the frame were plenty tight.
Thanks!
Drekkyk
07 CBR 600 RR
Old Jun 19, 2007 | 01:21 AM
KidCr3nshaw's Avatar
Default RE: Fairings, how tight?
Hand tight.
Dunno about the reflector bolts.
shok47
Mar 28, 2012 12:22 PM
dman81
Apr 24, 2010 08:26 PM
Onarom
Nov 24, 2006 06:12 AM
randall
Jan 16, 2006 04:11 PM
clean929
Jun 21, 2005 12:24 PM
