chain tension! how tight is to tight?
Old May 29, 2005 | 07:17 AM
clean929's Avatar
Default chain tension! how tight is to tight?
WHAT COULD HAPPEN IF THE CHAIN IS TO TIGHT? I KNOW THERE SHOULD BE SOME PLAY BUT WHAT COULD HAPPEN IT THE CHAIN HAD LITTLE TO NO SLACK?
Old May 29, 2005 | 04:01 PM
BlindLOKI's Avatar
Default RE: chain tension! how tight is to tight?
I DONT REALLY KNOW FOR SURE, BUT IT PUTS A LOT OF EXTRA STRAIN ON THE CHAIN. MEANING THAT IT WILL HAVE A MUCH SHORTER LIFE. PERHAPS IT WOULD BREAK FROM THE PRESSURE, NO CLUE. ALSO IT DOESNT HAVE THE ROOM IT NEEDS FOR YOUR REAR SUSPENSION TO WORK... I DONT THINK.
TAKE IT EASY,
chris> [sm=alcoholic.gif][sm=hia.gif][sm=hia.gif][sm=icon_beat.gif]
Old Jun 10, 2005 | 06:23 AM
ChiroRR's Avatar
What type of bike do you have? First look in the manual and see what the specs are? If the chain is too tight you can begin to damage sprockets, reduce chain life, and depending on the riding this can lock up your rear suspension travel. In a very fast turn this could mean bad news for you.
Old Jun 10, 2005 | 08:40 AM
Calkidd's Avatar
ORIGINAL: ChiroRR
The avatar and his nickname didn't give it away?
Old Jun 10, 2005 | 09:14 AM
chainstretcher's Avatar
Admin Emeritus & MVN
General rule is between 1" and 1 1/2" of slack -- RTFM for bike specific info. As to what could happen ... first you'll notice a clicking noise that does not go away -- at this point the chain is pretty much fried. The chain will stretch unevenly and can make a slapping noise. Worst case is you hit a bump and the suspension tightens up and the chain snaps and takes out your cases.
Old Jun 20, 2005 | 10:05 PM
VITIATED's Avatar
i hav a 954rr & the manual for mine say chain slack 1.6in-2in
Old Jun 21, 2005 | 12:24 PM
cbroar's Avatar
it can also put excessive pressure on the final drive oil seals resulting in a very messy repair job.
fastcbr
Mar 7, 2009 11:37 AM
ggoodling
Aug 25, 2008 10:59 PM
Carbon_cavvy
Apr 11, 2008 08:21 AM
sk8r20
Jun 27, 2006 11:21 AM
Angryviking
May 10, 2006 08:43 PM
