Hole in the crankcase and Warranty info
Old 11-06-2018, 04:45 PM
deadfred's Avatar
Default Hole in the crankcase and Warranty info
Hey guys so apologies if this is in the wrong spot, point me to the right place.
My bike is a used 2015 600rr. I got it with 2k miles on it, put on 2k of my own.
I was riding the other day, nothing too serious, when I saw another biker ahead of me. The road was clear, so I downshifted and sped up to ride along with him. As I am approaching, it feels like my bike slipped out of gear and went into neutral. I look out the mirror and there is smoke coming out of my bike, so I pull off to the side and notice that there is oil leaking as well... great. Also my chain is missing.
So I get it back to my garage and notice there is a big hole in the crank case, right above where the stator cover is. Looks like the water pump is a bit smashed as well but there was no coolant leaking. The front chain protector was in place and doesn't look like the chain could have gone past it.
So I know my engine is f'd and I'm unsure what to do here. Called honda, they confirmed my bike is under "extended warranty" with the previous owner, just have to get the dealership to transfer it over. Called the dealership, they say it will be about $600 to even diag the issue!!! before they can say it is covered or not.
What would you guys do here? I have a feeling the dealership will try their hardest to deny my claim and I really don't want to go through insurance here...
here's a pic you can see the top of the hole right in front of the sprocket...
Old 11-06-2018, 04:48 PM
deadfred's Avatar
Here's a video of the hole in question...
Old 11-06-2018, 05:24 PM
74demon's Avatar
Did you go back and get the chain so you can inspect it? It's obviously the chain that caused the issue. If they can prove that the failure was caused by neglect on your part, they may deny the claim. Do you have any service records on the chain?
The dealership should be on your side of things. They want to fix it. They want to get paid.... The extended warranty is through an insurance company.
Old 11-06-2018, 06:08 PM
boredandstroked's Avatar
Obviously not a defect they made therefor they will not cover the issue. Don't waste your money. I was a service writer for Honda for a couple years. Unless you have the broken chain to show its in perfect shape they will claim it wasn't maintained causing the break.
Old 11-06-2018, 07:16 PM
deadfred's Avatar
OK so I was quick thinking and went and got my chain from the road https://i.imgur.com/U9cVLTz.jpg
It's a bit scuffed up I think some body ran it over... Master link is missing tho... Any thoughts?
Old 11-06-2018, 08:37 PM
sjona2011's Avatar
What type of master link was it? Clip or rivet? Was it a chain you or the PO installed or factory?
Old 11-07-2018, 11:36 AM
deadfred's Avatar
It was riveted on, unsure about if it was PO or factory.
Pswid
05-12-2011 02:10 PM
mnazary
04-02-2010 09:30 AM
bjmsdrum00
04-13-2008 10:34 PM
mjlannin
07-19-2007 05:59 PM
smarterben
04-07-2006 03:59 PM
Quick Reply: Hole in the crankcase and Warranty info
