F4I - couple problems/questions
Old 11-03-2010, 02:18 AM
JT 02 F4I's Avatar
Default F4I - couple problems/questions
Hey there, new to the forum. First post!
I'm still fairly new to riding and not sure what the problem is. I noticed the other day my F4i was riding a little bumpy, or jumpy? in 1st and 2nd gear, like the bike lurched forward as i was cruising through the neighborhood. I also have noticed that the bike has been idling higher than usual, off and on. There is no FI light, and i replaced both the IAT and map sensor on it not long ago so i'm not sure what else it could be, or if the two problems are related?
Any ideas or suggestions? lemme know what you think! thanks
Old 11-03-2010, 05:08 AM
justasquid's Avatar
the first thing I would check would be the chain. if its too loose, it will create a jumpy feeling as the bike deals with the excess slack. Also, if the chain is old, rusty or not properly maintained with lube, the links can stick and the won't make a smooth transitions across the sprockets. This is also more noticable in lower gears, especially if your just cruising at a slow speed.
concerning the varing idle. It could be a sign of a fuel pressure regulator starting to fail. Its not really sign in itself, But its a common issue with the F4i. Just something to keep an eye on.
Old 11-04-2010, 01:13 PM
JT 02 F4I's Avatar
Yeah the chain is pretty new, that will be the first thing i check. Is there anyway to tell for sure if the FPR is going out?
Old 11-04-2010, 01:43 PM
justasquid's Avatar
If the chain is newer, its probably just loose. They stretch quite a bit initially.
As for the FPR, the most common issue is the diaphram failure. You can pull the vacuum line off and see if there is any sign of gas. If there is, then it is failing. But, it really doesn't sound like it is, I was just throwing htat out there so you knew about the common issue.
Old 11-04-2010, 02:33 PM
JT 02 F4I's Avatar
Ok awesome thanks for the info! I'll see how it goes
camaropower
03-18-2009 04:45 PM
mib7289
09-30-2008 01:06 PM
capuchin
03-31-2008 03:44 PM
roldaphat9
09-14-2006 10:28 AM
need4speed
05-14-2005 08:42 AM
Quick Reply: F4I - couple problems/questions
