F3 wont drive
Old Sep 4, 2013 | 11:33 AM
LT.Dan603's Avatar
Also check the solder joints in your switches you could have one that is just barely hanging on and looses conection from vibration
Old Sep 6, 2013 | 01:51 PM
FOGeologist's Avatar
Senior Member and ROTM March 2014
I wonder if there's a heat-soak issue here? Could this be a vapor-lock problem? Perhaps a furl pump challenge?
Old Sep 7, 2013 | 08:07 AM
Originally Posted by 87turbobuick
98 cbr f3 will idle allllll day long but if i go to ride it it just bogs i have new filter pump and cut relay in it and tue vent is clear and im getting fuel flow. im so stumped here guys any input would be greatly apreciated. is their a load sensing device of sorts that can cause it to do this.? i can rev it out as much as i want and no problem...i need help bad
When you say new, is it brand new, or new to the bike ? The f3's are notorious for having fuel pumps go bad. It's very conceivable that a replacement off another bike has the same issues.
When it bogs out, is it like a switch was turned off, which would indicate an electrical issue ? Or a sputter and cough like it's running out of fuel ?
Is your speedometer working ? The Air Vent Solenoid is turned off when the bike reaches 12 MPH. A simple test is just to unplug it. That is what controls the source of air flow between the small tubes below the headlight and the main air duct below the triple tree's.
Old Sep 9, 2013 | 04:51 PM
87turbobuick's Avatar
it bogs as if the switch was hit but only while driving ....never while idling and the fuel components are all brand new. . that was going to be my next step was checking the vent solenoid....i checked the vent tubes themself when i cleaned the carbs. and they were clear and all connected... it just sux now hecause riding season is just about over and i havent really ridden since may :'(.
Old Sep 9, 2013 | 04:53 PM
and yes the speedo is working.....and ill check all those solder joints in the switch and connections through out the harness
Old Sep 11, 2013 | 05:41 PM
Dirtrider009's Avatar
Rectifier.regulator could be failing. Itll run fine when its cool, but once it heats up it fails and this occurs. Its a common problem. Cheap fix with an ebay purchase.
C Jacob W
Jul 29, 2013 11:03 AM
May 13, 2009 11:12 AM
Juliet
Dec 20, 2008 09:22 AM
tagger609
Jun 27, 2008 02:09 PM
mishab
Sep 7, 2007 01:00 AM
