Exhaust-power commander
Old Jan 4, 2006 | 01:36 PM
Repsol1's Avatar
Default Exhaust-power commander
What do you guys/gals think I should do? My Honda dealer says I should not put my rs-5 slip on until I get my power commander. Honda states it will cause the bike to run lean or rich depending on the rpm. Honda also states removing the cables from the exhaust valve will cause it to run a little rough at low end. Is there anyone that is running the rs-5 on there 05 cbr 1000 without any re-mapping.
Old Jan 4, 2006 | 02:02 PM
Tahoe SC's Avatar
Default RE: Exhaust-power commander
yea you'll run on the lean side but nothing bad enough to blow up your engine or anything.
you should run it with the PC3 dyno tuned to get optimal power.
but hey...the newer generation of bikes accounts for changes in a/f doesn't it?
i knowt he old skool f4i generation, etc. doesn't.
Old Jan 4, 2006 | 02:14 PM
sirlimpzalot's Avatar
The instructions for my RS-5 said DO NOT REMOVE THE CABLES from the housing, mine are zip tied out of the way but still connected..I ran mine for months without a Power Commander and it was fine, but it definately runs better with it
Old Jan 4, 2006 | 07:59 PM
Anubis's Avatar
I fitted mine without the PC3 first, i also removed the cables completley hey if a jobs worth doin ........ yeah. The bike Ran better than stock immediatley without the pc3, a little rich. I ran for 3 months before getting a pc3 and a custom map and man its a new bike.
Old Jan 4, 2006 | 10:05 PM
shraz's Avatar
have yoshi slipon and no pinging
Inferno170
May 13, 2012 04:15 PM
underdevistation
Aug 18, 2009 08:12 AM
JOS777
Apr 27, 2009 12:12 PM
CBRFOXTROT
Oct 17, 2008 04:00 PM
brandonchino
Jan 11, 2006 10:40 AM
