Engine switching off.
Just had a 12000 mile service on a 2009 Blade.
Went for a ride today and the engine turned off after about 3miles. Eventually got the bike started and went home. I went out again later and the same thing happened. It is as if someone is switching the "kill" switch on.I then had loads of trouble starting the bike. Do you think the Honda dealers have upset something, I did get them to remove the rear foot pegs.
Obviously, I will ring them tomorrow. Any one else had this problem. Thanks The Mass
This will sound weird but check your kickstand switch. Unscrew it from the kickstand and set it to where you start the bike then move it around a little to see if it kills the bike. It takes like a quarter turn to work right any less it might be bad. I had problems with my bike starting and when i rode it the bike would kill itself for a second then come back on when i hit a bump and it was the switch. just got worn out over time.
