Engine noise - normal or not?
Old Sep 23, 2012 | 06:43 PM
thealphalum's Avatar
Registered Users
Default Engine noise - normal or not?
Just recently got an 05 600rr with 28,000 on it. I have recently kind of noticed somewhat of a ticking sound. It seems to be coming more from the throttle side of the bike. I have pulled off the cct and that is working fine plus its not a rattling sound that is a associated with the cct. My next idea is the valves may need to be adjusted. I have read that it could just be me noticing the fuel injectors and that i am just being paranoid. I understand that its hard to determine sounds via text but any input is good input.
Thanks
Old Sep 24, 2012 | 01:30 PM
gotcbr's Avatar
It could be valve-ticking. When was the last adjustment?
Old Sep 24, 2012 | 01:32 PM
74demon's Avatar
Could also be an exhaust leak.
Old Sep 24, 2012 | 02:28 PM
Andr3w's Avatar
I had my bike for a little bit and it's always had a faint ticking to it.
Old Sep 24, 2012 | 03:35 PM
Registered Users
I honestly don't know when it was done last. It's probably due for it. Looking through the service manual and reading up on adjusting the valves I'm a little nervous to do myself, but I also don't have a trusted mechanic and don't want to have them drum up work.
Old Sep 24, 2012 | 05:12 PM
Conrice's Avatar
the valve lash usually goes DOWN in a ohc with a shim/buck style valve - so your valves should tighten up - and that won't cause a tick.
adjusting the valves is a bitch - but checking them is not. all you need is a set of feeler gauges from your local autozone. all you'll do is pop off the valve cover and check the clearances....
Old Oct 4, 2012 | 08:15 PM
Brandon Henson's Avatar
I really wanna learn how to adjust my valves local shop wants 650 bucks I was like wawawawawhattt lol
alpine175
Mar 24, 2011 01:33 AM
axnst1
Sep 5, 2010 08:47 AM
WAKEnBAKE
Sep 27, 2007 01:53 AM
younghutch
Sep 3, 2007 10:06 PM
