Engine Ice coolant change.. possible gelling?
Old Dec 1, 2010 | 08:26 AM
Lando's Avatar
Exclamation Engine Ice coolant change.. possible gelling?
I recently drained my old coolant and replaced it with Engine Ice coolant on my F4i. In between draining the old coolant I flushed the system out with distilled water. I filled the radiator up and ran the bike for a few minutes then drained, I did this process a few times.
My question is, the drained distilled water was never 100% clear and after the second or third drain, I filled the system up with Engine Ice. I have been reading stories about gelling in the system with the OEM coolant. Does anyone think there is enough concentration of old factory coolant to do this? Just a little concerned. Thx
Old Dec 1, 2010 | 11:38 AM
thirdgenlxi's Avatar
Ironmang
It is true that if engine ice mixes with any ethylene glycol antifreeze, it will gel. But if you flushed it several times with distilled water, you should be OK. How bad was the water draining out at the last flush?? Still have some green or almost clear?? And did you drain the overflow bottle too?
Old Dec 1, 2010 | 12:05 PM
Lando's Avatar
I drained the overflow bottle and filled with Engine Ice. The water looked completely clear when draining, it's only until I filled the clear gallon jug for disposal I noticed a light green tint.
Old Dec 1, 2010 | 12:15 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Question
I would fill the RAD and the over flow up with Distilled water. Start the bike up and let it warm up, so the thermosat opens up and flows thru the system. Shut the engine off. Let the engine and Rad. cool down and drain out the water and fill'er up with the engine ice. That should flush out the system.
Old Dec 1, 2010 | 02:49 PM
Lando's Avatar
Yes, thats what I did, actually twice. I ran the motor for about 5-10mins each time with distilled water in it. The distilled water had a light green tint still to it. Just wondering if that small amount is enough to cause issues.
Old Jan 31, 2011 | 12:55 PM
f3cbrAnt's Avatar
Question
hi, i see that you have no mention of using a hose,i don't have access to a hose and was going to-
1-flush my 98F3 without the use of a hose by using water (not distilled) in watering cans untill the water runs clear through the drainage points (on my bike thats at the water pump and the bottom of the oil cooler casing)
2-then go through the flushing process with a flushing compound
3-then run water through the system again,-drain
4-then fill with the right amount of coolant mixture.
my question is,-
step 1? can i run water through the entire system by watering cans,or will the there be a lack of pressure to get past the water pump?
many regards,safe riding
Ant.
jamescbr87
F2 Tech
Jun 16, 2012 03:49 AM
live4liftin
F2 Tech
Mar 18, 2010 07:14 PM
Ride Red Bull
Jan 20, 2009 09:33 PM
Glocker23
May 9, 2008 11:31 AM
rustler84
May 1, 2008 07:33 PM
