do you know 2005 cbr 1000rr
Old 01-13-2009, 02:31 PM
aj_jensen73's Avatar
Default do you know 2005 cbr 1000rr
I have posted this before but I am going out to my shop right now to work on my baby and see if I can get her running, heres the deal its a 2005 cbr 1000rr that was in a wrecka while back and hasnt ran since then. I have replaced the following parts
-Radiator
-ECU
-Gauge cluster
-blown 10A and 20A fuses
-Master brake cylinder
-Master clutch cylinder
-front wheel
-ignition
-tripple tree
-forks
-new fearing kit
What I am having issues with is starting my baby, She turns over but wont start, the following are things I have check
-Fuel
-Fuses
-Battery
-Fuel pump does not engage when ignition is turned on but i have tested the pump it self and it works fine
-I make sure if it in Nuetral,Kill switch is not ingaged,clutch in and the stand it up, the Tilt sensor on the headlights is up right. is there any way of testing any of the sensors to double check they didnt get damaged during the accident? Please if you have any suggestions and I mean ANY please let me know and ill try it, Im going krazy with my baby just sitting in my shop and not being ridden!
Thanx everyone
The more info you can give me about testing/checking stuff the better!
Old 01-13-2009, 03:01 PM
Default RE: do you know 2005 cbr 1000rr
ok so I am out working on my baby and the kill switch that is mounted under the front master brake cylinder has damage to the plastic outside of it so that is why I didnt think it would be damaged on the inside but screw it they are only $13 so Im gonna order one and give it a shot after that. is there any way of testing my bank angle sensor with a test lite or voltmeter?
Old 01-13-2009, 04:39 PM
DWT74's Avatar
Make sure the speedo/tach is plugged in to the wiring harnest on the upper fairing. If its not plugged it all the bike will do is spin over and the fuel pump wont power up. Did you have to replace the odo/tach case that hold it together, if so where did you find one at? That case is $130 at my stealership and i need one for my 04.
Old 01-13-2009, 05:08 PM
Ya it is plugged in and it is all brand new, I had to order the whole tach/speedo cluster and I got sick of looking for it on ebay and craigslist so I bought if off of bikebandit.com they will have the one for your bike as well its just a matter of how much it is for yours.
robz
03-25-2009 11:12 AM
Balamien
01-29-2008 07:20 AM
hondadriver4life
05-04-2006 06:36 PM
Quick Reply: do you know 2005 cbr 1000rr
