HRC KIT FOR THE 2005 CBR 1000RR
i have been busting my *** to try and find more info about this kit that hrc offers and every person i talked to at honda and hrc said that they do not sell the parts to the kit in the us. one rep. suggested that the only way to get the kit is to call japan and have somebody over there ship it to you. the one thing i did come up with is the part numbers for all the pieces in the kit:
PARTS NUMBER DESCRIPTION
00X32-NL9-710 SET UP MANUAL PARTS LIST
06110-NL9-710 ENGINE POWER UP KIT III, SBK
06180-NL9-710 CAM SPROCKET SET
06190-NL9-710 OIL PUMP SET
06230-NL9-710 BTL CLUTCH SET
06130-NL9-710 ACG SET
06240-NL9-710 CRANKCASE SBK SET
06160-NL9-710 AIR FUNNEL SET
06175-NL9-910 TANK SET FUEL
06183-NL9-710 EXHAUST SET Ti (SBK)
06443-NL9-720 FR AXLE SET
06502-NL9-910 SEAT TAIL SET
23212-NL9-710 SHAFT, MAIN P-2, BTL
23212-NL9-910 SHAFT, MAIN P-2
23211-NL9-710 SHAFT, MAIN, BTL
23213-NL9-710 SHAFT, MAIN P-3, BTL
23213-NL9-910 SHAFT, MAIN P-3
23422-NL9-710 GEAR, C-1 P-2
23423-NL9-710 GEAR, C-1 P-3
23432-NL9-710 GEAR, M-2 P-2
23442-NL9-710 GEAR, C-2 P-2
23443-NL9-710 GEAR, C-2 P-3
23452-NL9-710 GEAR, M-3 M-4 P-2
23453-NL9-710 GEAR, M-3 M-4 P-3
23454-NL9-710 GEAR, M-3 M-4 P-4
23462-NL9-710 GEAR, C-3 P-2
23463-NL9-710 GEAR, C-3 P-3
23482-NL9-710 GEAR, C-4 P-2
23492-NL9-710 GEAR, M-5 P-2
23493-NL9-710 GEAR, M-5 P-3
23502-NL9-710 GEAR, C-5 P-2
23503-NL9-710 GEAR, C-5 P-3
23512-NL9-710 GEAR, M-6 P-2
23513-NL9-710 GEAR, M-6 P-3
23522-NL9-710 GEAR, C-6 P-2
12256-NL9-710 GASKET, CYLINDER HEAD 0.55
13214-NL9-711 BRG, CONN-ROD, A
13215-NL9-711 BRG, CONN-ROD, B
13216-NL9-711 BRG, CONN-ROD, C
13217-NL9-711 BRG, CONN-ROD, D
13218-NL9-711 BRG, CONN-ROD, E
13219-NL9-711 BRG, CONN-ROD, F
13220-NL9-711 BRG, CONN-ROD, G
13314-NL9-711 BRG, CRANK SHAFT, B
13315-NL9-711 BRG, CRANK SHAFT, C
13316-NL9-711 BRG, CRANK SHAFT, D
13317-NL9-711 BRG, CRANK SHAFT, E
13318-NL9-711 BRG, CRANK SHAFT, F
13319-NL9-711 BRG, CRANK SHAFT, G
13320-NL9-711 BRG, CRANK SHAFT, H
22336-MEL-R20 SPRING SEAT, JUDDER
42650-NL9-710 WHEEL ASSY, RR 16.5×6.25
44650-NL9-710 WHEEL ASSY, FR 16.5×3.5
64501-NL9-910 STAY, UPPER COWL
http://world.honda.com/HRC/products/...it/lineup.html
hope this helps. now its off to work i go!!!!!!!!!!!!
RE: HRC KIT FOR THE 2005 CBR 1000RR
