Digital Speedometer Problems F3
Old Oct 22, 2013 | 07:38 AM
Jonesc962's Avatar
Default Digital Speedometer Problems F3
So I have a 1991 CBR 600 with a CBR F3 engine and most electrical parts. My issue comes when I'm attempting to put a digital speedometer that has a analog or cable driven speedo connection onto my F3 engine that has the 3 wired speed sensor. I'm lost on what I can do.
Here is the cheapo speedo I got. LCD Digital Speedometer Odometer Tachometer for Motorcycle ATV Scooter Dirt Bike | eBay
You can see if you scroll through the pics where the speedo cable would connect to on the back.
Old Oct 22, 2013 | 10:15 AM
Jonesc962's Avatar
So it looking like this is my situation. It looks like if I cannot work from electrical speedo to mechanical. Then what I have to do is work backward and go back to mechanical only. As in speed cable on an F2. So here is another question, I have a F3 fork, wheel, and rotors. Can I put an F2 front wheel speed sensor like this??
1991 Honda CBR 600 CBR600 F2 Speed Cable Speedo Speedometer | eBay
Or will it not fit on the F3 fork? Or do you have any other suggestion on how I can make my mechanical speedometer input on my my new gauges work?
Old Oct 26, 2013 | 10:37 AM
I don't see why the electronic one wouldn't work. If it comes with documentation, you should be able to find a source of ignition for the engine rpm. As for speed, it sounds like it uses a magnet and Hall effect IC to detect the rotation of the wheel. This would most likely be a magnet that gets attached to the wheel somewhere and a sensor mounted to the fork or swingarm somewhere so it detects the magnet as it goes by.
As for F2 and F3 fork parts, they're not interchangeable.
Old Oct 28, 2013 | 11:48 AM
Jonesc962's Avatar
Thanks for the replies! I'm just going to put a trail tech vapor on there and be done.
Jonesc962
Oct 22, 2013 10:46 PM
celepano
Jun 3, 2012 09:38 AM
loki32687
May 30, 2012 09:18 PM
jordan1210
Aug 17, 2011 10:02 PM
RRip
May 31, 2005 11:19 PM
